Has anyone had a case where the Elecra mk2 won’t boot up after not using it for a long time. I have tried all the advice on the site ie holding bottom right button etc but nothing works. When I put the lead in, it extremely briefly shows a very slight flash of light on the screen then nothing at all. It is plugged directly into my pc. I haven’t used it maybe for a year after simplifying a set up for live and is quite cold but am ready to get using again. Would that be why? It was absolutely fine when I last used it and has been covered since. Would anyone have any ideas at all?
First thought would be the USB cable and whatever you are using to power it. Try a USB power block plugged directly into the wall first.
Thanks very much for that. Tried but no different.
Hi, the symptoms you describe point to an issue with the SD card. There is a troubleshooting guide for that at: A broken SD card | Electra One Documentation
SD card images can be found at: 4.1.4 Downloads
Thanks very much, Martin. Will have a look, thank you very much for that.
Thank you so much, Martin. All up and running with the latest firmware now. Perfect, thank you.
