Micromonsta 2 not being recognized via USB
Greetings all,
I’m having dofficulty getting the micromonsta 2 to be recognized by the electra one mini via usb. Tried various cables*, etc., no luck. Anyone have success with this? Or can point me to any resources to try different settings, strategies to work it out?
edit: both mini and micromonsta 2 are updated to the latest firmware.
welcome here! When you connect another USB MIDI device, is it recognized?
Yes - my dreadbox nymphes shows up without issue.
ok, I will try to find out info about micromonsta’s USB implementation.
From audiothingies support:
"Check out the new v3 firmware and its documentation (in downloads, you’ll get full NRPN documentation).
It should work with elektra one, a couple beta testers have the same setup."
I’m going to start from scratch with the newest firmware on both clean devices to make sure I’m not the issue.
Welp I take everything back. After starting from ground zero with the latest firmware on both devices, it is now recognizing the micromonsta without issue.
