I have an Electra.One mk II (for about 3 years) that I haven’t used in a while. I just upgraded to version 5.0.6 and am now trying to load projects onto the E1 from my web browser. It works, but unfortunately the E1 forgets all the installed presets as soon as it’s disconnected from the USB. I’ve looked at the manuals and the website to find any way to tell the E1 to save its state… but I haven’t found anything.
Whenever you upload a preset to the controller, it goes straight to RAM and gets flushed to the SD card asynchronously a few moments later (~ 1sec).
What you describes sounds like that the USB transfer goes ok but the write to the storage fails. I would check the logs. To fix it, either format the card and restore the files on it manually. Or, as of firmware 5.0.3, you can have the controller to the job for you: hold the top-left and middle-left buttons pressed simultaneously when you connect the USB cable (or reset it using the recessed button). It is a bit difficult to do but that is on purpose, it is quite a destructive action. It will format the card and create the essential folder structure on it. The formatting/restore of the files takes around 10 seconds, then the controller restarts.
If this does not help, the card may have a hardware problem.
I reformated the SD-Card (hold the top-left and middle-left) and now I can store some presets over a reboot. But preset slot 2 won’t store anything. I think the SD card is damaged. I will try to open the E.1 and replaced the SD card.
It sounds like that you have one of the earlier mk2s - no SD card slot on the side of the controller - you will find the SD card slot under the bottom plastic cover.
