Hi there,
I’m trying to control my Kiwi Juno-106 with NRPNs but unfortunately I haven’t figured out how to properly configure it…
It supports 12 bit controls (0-4096) and it combines 7 bits of the MSB and 5 of the LSB. See the extract from the manual below.
I tried to modify the code below for hours to try to get it work but with no success unfortunately. I must confess bit shifting/combining is unknown territory for me… I’m also not able to monitor the synth’s output because it sends only 7 bit CCs…
I got the code from this topic: https://forum.electra.one/t/nrpns-bits-and-bytes/3319. Props to the autors.
deviceId = 1
device= devices.get(deviceId)
devPort = device:getPort ()
channel = device:getChannel ()
function sendNrpn(ValueObject, value)
local message = ValueObject:getMessage ()
local parameterNumber = message:getParameterNumber ()
local parameterMSB = (parameterNumber >> 7) & 0x7F
local parameterLSB = parameterNumber & 0x7F
local valueMSB = (value >> 7) & 0x7F
local valueLSB = value & 0x7F
local messages = {
{channel = channel, type = CONTROL_CHANGE, controllerNumber = 99, value = parameterMSB},
{channel = channel, type = CONTROL_CHANGE, controllerNumber = 98, value = parameterLSB},
{channel = channel, type = CONTROL_CHANGE, controllerNumber = 6, value = valueMSB},
{channel = channel, type = CONTROL_CHANGE, controllerNumber = 38, value = valueLSB}
for i, msg in ipairs(messages) do
midi.sendMessage(devPort, msg)
Does anybody know how to solve this problem ?
