Maybe a stupid question. Some synths have parameters as CC and sysex. Waldorf Blofeld is a good example. Many of the parameters are CC but some are sysex like Osc 1 PWM Source (F0 3E 13 00 20 00 00 0A value F7). When I turn the pot on Electra, it sends the sysex parameter to my Blofeld. Blofeld reacts correctly. But when I turn the pot directly on Blofeld, Electra does not react.
I understand that you have to map a sysex dump so that you can send a patch request from Electra and get Electra to set all the parameters correctly, but… Do you have to do the same in this case too?
The only thing I want to work right now is for Electra to react when I turn directly on Blofeld, not request a dump.
Yes, you will have to parse the sysex as well, but I wouldn’t do that the same way as a regular patch dump, it would require a lot of variants to make.
Instead you should build some logic in lua to parse such incoming sysex as cleverly as possible.
Especially as many synths have a completely different format for individual parameter changes via sysex vs patch dumps via sysex
This works really good. I get the parameter value from the sysex message and set the control to that value.
Here is an updated version that can handle different parameters. 10, 14, 16 is the sysex parameter. 22, 5, 8 is the control id that will be updated with the value from the sysex message.
I’m always looking for a better way no matter what I do. @Martin, is there a better way? I think it would be incredibly good if sysex parameters just worked like CC and NRPN. Add a sysex parameter to a control and you have two-way communication right out of the box.
