Hi, in my Notes transmittor I have a lot of pages where controls 1-16 and 19-34 are controls for midi channels 1 - 16. I want to change their colors using the first 16 on/off values on the first page, with a function called applyColor(value,channel). When value = 0, it turns the other control’s color in red else it turns it in white (for channels 1-4 or 9-12) or blue (channels 5-9 or 13-16).
All this works, but the codes does something unwanted: it also changes the controls 19-34 on the first page in type , color and value!
When the function is called with value 0, it turns the corresponding control that is 18 controls further down on page 1 also in red and in a on/off control in the off state with the name inherited from the valueObject the function was called from
When the function is called with value 1, it turns the corresponding control that is 18 controls further down on page 1 in corresponding white/blue and in a on/off control in the off state.
When I move the focus onto the changed controls, they revert back to the types and colors they are supposed to be.
If the weird control receives a different value from elsewhere, it also reverts back to the type and color it issupposed to be.
What causes this temporary identity theft?
Here’s the function I use. If you can’t reproduce the effect, tell me how to get the preset and/or code to you.
function applyColor (value,channel)
local color = BLUE
if value ==0 then
color =RED
elseif math.floor((channel-1)/4) == 0 or math.floor((channel-1)/4) == 2 then
color = WHITE
controls.get ( 36+channel):setColor (color)
controls.get ( 72+channel):setColor (color)
controls.get ( 90+channel):setColor (color)
controls.get (144+channel):setColor (color)
controls.get (216+channel):setColor (color)
controls.get (234+channel):setColor (color)
controls.get (252+channel):setColor (color)
controls.get (270+channel):setColor (color)
controls.get (288+channel):setColor (color)
controls.get (306+channel):setColor (color)
controls.get (324+channel):setColor (color)
