The situation is this -
- I want to have two sysex controls (‘Level Type’ and ‘Level Value’) operating on the same (bipolar) target parameter.
- Level Value has a range of +/- 127 and is typical for the target device (14-bit two’s complement, with the sign bit at position 14 (ls bit)).
- Level Type has a range of 0-3 and is bit-shifted into the lsb of the parameter value string.
So I basically want to add the two controls together in the output - i.e. the Level Value sign bit gets added to the bit-shifted Level Type within the lsb.
Am I correct in thinking I can’t use the sysex byte detail window within the web editor to implement this, as the ‘linked parameters’ feature only operates on parameter bits 0-7 within the string?
