Hi everone,
I’m creating a preset for the Korg 01RW. It is very similar to the Korg 03R/W which I already made.
But there are 3 types of mass changes to perform. See below in the Topic.
I can change this of course in the json of the preset, and upload this into the E1, but then I can no longer use the editor for maintaining that preset.
=> Is there a way I can perform the necessary mass changes, outside the editor and then load them back again into the editor ?
The necessary changes are:
1 There is a bit sequence
"42",
"type": "function",
"name": "getChannelByte"
"30",
"41",
I need to replace with
"42",
"type": "function",
"2B",
"41",
"00",
in hundreds of places.
- I also need to reshuffle the multisound list, and provide other names for each sound in the list
"value": 86,
"label": "hardflute 2",
"index": 86
"value": 87,
"label": "pan flute",
"index": 87
"value": 88,
"label": "pan flute lp",
"index": 88
"value": 89,
"label": "shakuhashi",
"index": 89
"value": 90,
"label": "bottle",
"index": 90
"value": 91,
"label": "bassoon",
"index": 91
"value": 92,
"label": "oboe",
"index": 92
- Last but not least, I need to offset certain parsing bytes with 4 to 8 bytes in the json like in the code below where 149 must become 153, 150 => 154 etc…
"parameterBitPosition": 2
"parameterNumber": 1208,
"type": "virtual",
"byte": 149,
"bitWidth": 1,
"byteBitPosition": 1,
"parameterBitPosition": 3
"type": "virtual",
"byte": 149,
"bitWidth": 1,
"byteBitPosition": 6,
"parameterBitPosition": 4
"type": "virtual",
"byte": 149,
"bitWidth": 1,
"byteBitPosition": 2,
"parameterBitPosition": 5
"type": "virtual",
"byte": 144,
"bitWidth": 1,
"byteBitPosition": 4,
"parameterBitPosition": 6
"type": "virtual",
"byte": 149,
"bitWidth": 1,
"byteBitPosition": 3,
"parameterBitPosition": 7
"parameterNumber": 1237,
"type": "virtual",
"byte": 150,
"bitWidth": 1,
"parameterBitPosition": 0
"type": "virtual",
"byte": 150,
"bitWidth": 1,
"byteBitPosition": 0,
"parameterBitPosition": 1
"type": "virtual",
"byte": 150,
"bitWidth": 1,
"byteBitPosition": 5,
"type": "virtual",
"byte": 150,
"bitWidth": 1,
"type": "virtual",
"byte": 150,
"bitWidth": 1,
"type": "virtual",
"byte": 150,
"bitWidth": 1,
"type": "virtual",
"byte": 144,
"bitWidth": 1,
"type": "virtual",
"byte": 150,
"bitWidth": 1,
"parameterNumber": 1229,
"type": "virtual",
"byte": 151,
"bitWidth": 1,
"type": "virtual",
"byte": 151,
"bitWidth": 1,
