Martin, I feel like I’ve found a bug. (It could also be incorrect use of LUA code.) Look at my pictures.
First I add two option lists.
The result in Electra display is like this.
That is correct. Option list called ‘FUNCTION’ has three values as it should. LUA code also added a name and a overlay the to second option list.
Then I add another option list.
That is correct. Option list called ‘FUNCTION’ still has three values.
If I move the option list to be first.
This is NOT correct. Look at the option list called ‘FUNCTION’, it has now four values. it should have three.
I also have some LUA code.
– define values and labels
local lists = {noise = { { value = 0, label = "High" }, { value = 1, label = "Low" }, { value = 2, label = "Peak" }, { value = 3, label = "Decin" } }, vpn = { { value = 0, label = "Sin1" }, { value = 1, label = "Sin2" }, { value = 2, label = "Sin3" }, { value = 3, label = "Sin4" }, { value = 4, label = "Saw1" }, { value = 5, label = "Saw2" }, { value = 6, label = "Sqr1" }, { value = 7, label = "Sqr2" }, { value = 8, label = "Fat1" }, { value = 9, label = "Fat2" }, { value = 10, label = "Air1" }, { value = 11, label = "Air2" }, { value = 12, label = "Decay1" }, { value = 13, label = "Decay2" }, { value = 14, label = "Creep" }, { value = 15, label = "Throdt" } }, user = { { value = 0, label = "Waves" }, { value = 1, label = "User2" }, { value = 2, label = "User3" }, { value = 3, label = "User4" }, { value = 4, label = "User5" }, { value = 5, label = "User6" }, { value = 6, label = "User7" }, { value = 7, label = "User8" }, { value = 8, label = "User9" }, { value = 9, label = "User10" }, { value = 10, label = "User11" }, { value = 11, label = "User12" }, { value = 12, label = "User13" }, { value = 13, label = "User14" }, { value = 14, label = "User15" }, { value = 15, label = "User16" } }}
– create overlays
overlays.create(2, lists.noise)
overlays.create(3, lists.vpn)
overlays.create(4, lists.user)function set_function(valueObject, value)
– your code goes here
if value == 0 then
controls.get(2):setName(“NOISE”)
– set overlay
controls.get(2):getValue():setOverlayId(2)
endif value == 1 then controls.get(2):setName("VPN") -- set overlay controls.get(2):getValue():setOverlayId(3) end if value == 2 then controls.get(2):setName("USER") -- set overlay controls.get(2):getValue():setOverlayId(4) endend
UPDATE: I just discovered that it’s only the option list (if I put it above the rest) that causes the error.
This works:
Not this:
