Just wondering if it would be possible to combine multiple bytes in one single SysEx function.
Thing is, in a D-50 preset the following sequence of 5 bytes is repeated in about 250 different SysEx controls.
"41",
"type": "function",
"name": "getChannelByte"
"14",
"12",
"00",
Wouldn’t we be able to save memory, if we could combine all 5 bytes together in one single function? That way we could use the freed up memory to enrich the preset with other capabilities. If that is already possible , can someone show me?
Not near my E1 for a few days, but the way I would research it is to have each control call a central “send sysex to the D-50” function and pass it only the data that matters for each control. That central “send to D-50” function would wrap the info passed in with the standard 5 bytes and send it.
Things to research -
- can this be only done with virtual functions for everything?
- how to pass an array of bytes to another function?
- if each control can send a different number of bytes, you’ll need to pass a length or something as well
- is the added overhead of calling a function and passing data around still taking up a lot of room?
Just some quick thoughts
makes sense… will try a POC later
