Set message value without sending midi
Is it possible to prevent a midi message being sent when the value of a message is changed with a function call <message>:setValue(newValue)?
What i want to achieve is updating the value of the pots by incoming sysex messages from a DAW. But the pots shouldn’t fire a cc message in response, because this will lead to a midi loop with the DAW sending the sysex messages and ultimately lead to a crash of the DAW. The pots should only emit midi messages when they are turned on the E1 controller.
Maybe not the most elegant solution, but you could set the pot to type virtual and write a custom handler for the pots, that checks if a message was being sent before processing the value.
A very handy callback is parameterMap.onChange.
The first line in the function is enough to reach what you want.
function parameterMap.onChange(valueObjects, origin, value)
  if origin == MIDI then return end
    for i, valueObject in ipairs(valueObjects) do -- -- onChange manually or via LUA
    local parameterNumber = valueObject:getMessage ():getParameterNumber ()
    local parameterType = valueObject:getMessage ():getType ()
    if parameterType ~= PT_VIRTUAL then return end
    -- from now on only virtual parameters, manually changed
The 4.0 has a Lua function (a method of the parameterMap) that allows setting the value without triggering all associated actions (sending a message, triggering callbacks, etc). I will provide all necessary info when the beta firmware is okayed by the community.
Can you please describe the function you’re referring to, i.e. how to change the displayed control value to match a received value (eg in a sysEx message) without sending MIDI back out?
The code shown by NewIgnis above prevents incoming MIDI from being sent back out, but doesn’t alter the displayed control value.
I think I have a solution by also excluding LUA (in addition to MIDI) from the origin based parameterMap.Onchange response as follows:
if origin == MIDI or origin == LUA then return end
And in the sysex LUA response code using:
 local devID = controls.get(ctl):getValue():getMessage():getDeviceId()
 local paramType = controls.get(ctl):getValue():getMessage():getType()
 local param = controls.get(ctl):getValue():getMessage():getParameterNumber()
 parameterMap.set(devID , paramType, param, val);
Is that what you were referring to, or is there a simpler solution?
@martin Has this functionality been implemented yet? I couldn’t find anything in the docs.
as of v4.1.0 there is a function parameterMap.updateValue() that takes the same parameters as parameterMap.set(). That function updates the corresponding parameter in the parameterMap and does not trigger any MIDI messaging or Lua functions.
Martin, could you add all new parametermap functions to the lua extension section please?
Can we add this to the documentatation please?
any more on how to implement this? I have a few presets that would greatly benefit from having controls GUI values change based on various LUA stuff
