Hi there.
Just starting to look at sysex, I know it starts with f0, finishes with f7, there’s an identifying section for the gear and a variable often and that’s the sum total of my sysex knowledge. I’ve been looking at the output from a V synth xt and capturing it in the E1.
This is the file in question, I captured the controls 0-1 and 1-2 and these do exactly what I expected, altering the parameter. Looking at these I made the control called ‘doesn’t’ expecting it to give me the result 2-3 but it didn’t work as expected. So I captured the control 2-3 and on comparing 2-3 with ‘doesn’t’ they look like identical sysex strings. It’s COSM 1 filter cutoff if that makes any difference.
I expected to see a constant sysex string with a single variable that I could map to a knob but I see two values changing, the 13th hex appears to be the variable in question, mapping directly to the cutoff values but hex 14 is also changing but decreasing.
Any pointers would be great.
