I have a 7-bit CC fader, set up to control the dry/wet mix for an effect.
The value runs from 0-127, but I want to display it as a value running from -63 to +64. So far, so good.
Then I’ve assigned it three overlay texts which speak for themselves.
However when I upload this in the E1, the -63 value is not getting its overlay, and the 0-value shows ‘DRY’ instead of the intended ‘50/50’.
The work-around currently is: do not using an overlay text for a negative value.
while we are at it: the Text Overlay editor is referring to values as MIDI values, but they rather operate as Display values.
Thanks for the tip, but it doesn’t resolve the issue. While keeping all other parameters the same and only changing the Sign mode, what happens (see below) is exactly the same behaviour as in unsigned mode.
Two’s complement mode, 8 Bit width
Value -63 shows -63 instead of ‘DRY’
Value 0 shows ‘DRY’ instead of ‘50/50’
Value 64 shows the desired ‘FULL WET’
Sign bit mode, 8 Bit width
When I delete the -63 ‘DRY’ text overlay from the list, then the behaviour becomes:
