Happy New Year! I found the problem with the Lua Editor log, it will not work when Electra MIDI 3 i/o is being used any other app on Windows 10. I had Bitwig open which by default opens and uses the Electra Bitwig preset. Closing Bitwig allows the editor log to start working.
With debug activated, when I press the E1 physical buffer request button, and the % control is set to ‘+VCF’, the editor log shows the following data. The Log Level is by default set to ‘Critical’. Do I need to change that to another setting? The preset is still just parsing the system and common buffers.
14:21:13.816 lua: L360: midiValue 512, origin 1
14:21:13.817 lua: L360: midiValue 512, origin 1
14:21:13.818 lua: L360: midiValue 64, origin 1
14:21:13.818 lua: L360: midiValue 4, origin 1
14:21:13.819 lua: L360: midiValue 0, origin 1
14:21:13.820 lua: L360: midiValue 127, origin 1
14:21:13.820 lua: L360: midiValue 0, origin 1
14:21:13.821 lua: L360: midiValue 0, origin 1
14:21:13.821 lua: L360: midiValue 1, origin 1
14:21:13.822 lua: L360: midiValue 1, origin 1
14:21:13.823 lua: L360: midiValue 8, origin 1
14:21:13.823 lua: L360: midiValue 4, origin 1
14:21:13.823 lua: L360: midiValue 64, origin 1
14:21:13.824 lua: L360: midiValue 2, origin 1
14:21:13.824 lua: L360: midiValue 12, origin 1
14:21:13.825 lua: L360: midiValue 41, origin 1
14:21:13.825 lua: L360: midiValue 42, origin 1
14:21:13.826 lua: L360: midiValue 43, origin 1
14:21:13.826 lua: L360: midiValue 44, origin 1
14:21:13.827 lua: L360: midiValue 45, origin 1
14:21:13.827 lua: L360: midiValue 46, origin 1
14:21:13.828 lua: L360: midiValue 47, origin 1
14:21:13.828 lua: L360: midiValue 48, origin 1
14:21:13.829 lua: #
14:21:13.830 lua: sysex message received on interface= 0 with a length of 39.0
14:21:13.832 lua: L168: genericHide parNum..4
14:21:13.833 function ‘runFormatter’ does not return value
14:21:14.450 lua: L360: midiValue 68, origin 1
14:21:14.450 lua: L360: midiValue 101, origin 1
14:21:14.452 lua: L360: midiValue 116, origin 1
14:21:14.452 lua: L360: midiValue 114, origin 1
14:21:14.452 lua: L360: midiValue 111, origin 1
14:21:14.452 lua: L360: midiValue 105, origin 1
14:21:14.453 lua: L360: midiValue 116, origin 1
14:21:14.453 lua: L360: midiValue 32, origin 1
14:21:14.454 lua: L360: midiValue 32, origin 1
14:21:14.455 lua: L360: midiValue 20, origin 1
14:21:14.455 lua: L360: midiValue 1, origin 1
14:21:14.456 lua: L360: midiValue 4, origin 1
14:21:14.456 lua: L360: midiValue 0, origin 1
14:21:14.457 lua: L360: midiValue 0, origin 1
14:21:14.457 lua: L360: midiValue 128, origin 1
14:21:14.458 lua: L360: midiValue 138, origin 1
14:21:14.458 lua: L360: midiValue 8, origin 1
14:21:14.459 lua: L360: midiValue 60, origin 1
14:21:14.459 lua: L360: midiValue 0, origin 1
14:21:14.460 lua: L360: midiValue 114, origin 1
14:21:14.461 lua: L360: midiValue 0, origin 1
14:21:14.461 lua: L360: midiValue 4, origin 1
14:21:14.462 lua: L360: midiValue 0, origin 1
14:21:14.463 lua: L360: midiValue 64, origin 1
14:21:14.463 lua: L360: midiValue 1, origin 1
14:21:14.464 lua: L360: midiValue 0, origin 1
14:21:14.465 lua: L360: midiValue 0, origin 1
14:21:14.466 lua: L360: midiValue 0, origin 1
14:21:14.467 lua: L360: midiValue 0, origin 1
14:21:14.468 lua: L360: midiValue 49, origin 1
14:21:14.468 lua: L360: midiValue 14, origin 1
14:21:14.470 lua: L360: midiValue 30, origin 1
14:21:14.470 lua: L360: midiValue 5, origin 1
14:21:14.470 lua: L360: midiValue 20, origin 1
14:21:14.470 lua: L360: midiValue 40, origin 1
14:21:14.471 lua: L360: midiValue 52, origin 1
14:21:14.471 lua: L360: midiValue 66, origin 1
14:21:14.472 lua: L360: midiValue 68, origin 1
14:21:14.473 lua: L360: midiValue 10, origin 1
14:21:14.473 lua: L360: midiValue 0, origin 1
14:21:14.474 lua: L360: midiValue 0, origin 1
14:21:14.474 lua: L360: midiValue 50, origin 1
14:21:14.475 lua: L360: midiValue 4352, origin 1
14:21:14.475 lua: L360: midiValue 4378, origin 1
14:21:14.476 lua: L360: midiValue 2176, origin 1
14:21:14.476 lua: L360: midiValue 2197, origin 1
14:21:14.477 lua: L360: midiValue 4352, origin 1
14:21:14.477 lua: L360: midiValue 4378, origin 1
14:21:14.478 lua: L360: midiValue 0, origin 1
14:21:14.479 lua: L360: midiValue 128, origin 1
14:21:14.479 lua: L360: midiValue 137, origin 1
14:21:14.480 lua: L360: midiValue 0, origin 1
14:21:14.481 lua: L360: midiValue 0, origin 1
14:21:14.481 lua: L360: midiValue 54, origin 1
14:21:14.482 lua: L360: midiValue 0, origin 1
14:21:14.483 lua: L360: midiValue 0, origin 1
14:21:14.483 lua: L360: midiValue 25, origin 1
14:21:14.484 lua: L360: midiValue 0, origin 1
14:21:14.484 lua: L360: midiValue 5, origin 1
14:21:14.485 lua: L360: midiValue 0, origin 1
14:21:14.486 lua: L360: midiValue 10, origin 1
14:21:14.486 lua: L360: midiValue 256, origin 1
14:21:14.486 lua: L360: midiValue 321, origin 1
14:21:14.487 lua: L360: midiValue 0, origin 1
14:21:14.487 lua: L360: midiValue 79, origin 1
14:21:14.488 lua: L360: midiValue 0, origin 1
14:21:14.488 lua: L360: midiValue 18, origin 1
14:21:14.489 lua: L360: midiValue 0, origin 1
14:21:14.489 lua: L360: midiValue 46, origin 1
14:21:14.490 lua: L360: midiValue 1, origin 1
14:21:14.490 lua: L360: midiValue 0, origin 1
14:21:14.491 lua: L360: midiValue 16, origin 1
14:21:14.491 lua: L360: midiValue 1, origin 1
14:21:14.492 lua: L360: midiValue 0, origin 1
14:21:14.492 lua: L360: midiValue 1, origin 1
14:21:14.493 lua: L360: midiValue 7, origin 1
14:21:14.493 lua: L360: midiValue 50, origin 1
14:21:14.494 lua: L360: midiValue 0, origin 1
14:21:14.494 lua: L360: midiValue 100, origin 1
14:21:14.495 lua: L360: midiValue 0, origin 1
14:21:14.495 lua: L360: midiValue 100, origin 1
14:21:14.496 lua: L360: midiValue 1, origin 1
14:21:14.497 lua: L360: midiValue 6, origin 1
14:21:14.497 lua: L360: midiValue 64, origin 1
14:21:14.498 lua: L360: midiValue 43, origin 1
14:21:14.498 lua: L360: midiValue 0, origin 1
14:21:14.499 lua: L360: midiValue 0, origin 1
14:21:14.500 lua: L360: midiValue 10, origin 1
14:21:14.500 lua: L360: midiValue 0, origin 1
14:21:14.501 lua: L360: midiValue 0, origin 1
14:21:14.502 lua: L360: midiValue 0, origin 1
14:21:14.502 lua: #
14:21:14.503 lua: sysex message received on interface= 0 with a length of 1651.0
14:21:14.504 function ‘runFormatter’ does not return value
14:21:14.504 lua: L168: genericHide parNum..111
14:21:14.505 lua: L168: genericHide parNum..194
14:21:14.506 function ‘runFormatter’ does not return value
14:26:17.567 lua: L360: midiValue 0, origin 2
14:26:17.569 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:17.787 lua: L360: midiValue 64, origin 2
14:26:17.788 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:19.797 lua: L360: midiValue 0, origin 2
14:26:19.799 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:20.134 lua: L360: midiValue 64, origin 2
14:26:20.136 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:21.425 lua: L360: midiValue 0, origin 2
14:26:21.427 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:21.674 lua: L360: midiValue 64, origin 2
14:26:21.676 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:25.078 lua: L360: midiValue 0, origin 2
14:26:25.080 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:25.401 lua: L360: midiValue 64, origin 2
14:26:25.402 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:27.102 lua: L360: midiValue 0, origin 2
14:26:27.105 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:27.176 lua: L360: midiValue 64, origin 2
14:26:27.178 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:30.917 lua: L360: midiValue 0, origin 2
14:26:30.919 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:30.990 lua: L360: midiValue 64, origin 2
14:26:30.992 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:31.093 lua: L360: midiValue 0, origin 2
14:26:31.095 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:31.152 lua: L360: midiValue 64, origin 2
14:26:31.154 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:34.086 lua: L360: midiValue 0, origin 2
14:26:34.088 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:34.453 lua: L360: midiValue 64, origin 2
14:26:34.455 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:41.554 lua: L360: midiValue 0, origin 2
14:26:41.556 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:42.082 lua: L360: midiValue 64, origin 2
14:26:42.084 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:46.541 lua: L360: midiValue 0, origin 2
14:26:46.544 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:46.630 lua: L360: midiValue 64, origin 2
14:26:46.632 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:47.040 lua: L360: midiValue 0, origin 2
14:26:47.043 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:47.099 lua: L360: midiValue 64, origin 2
14:26:47.101 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:47.950 lua: L360: midiValue 0, origin 2
14:26:47.952 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:48.038 lua: L360: midiValue 64, origin 2
14:26:48.040 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:48.229 lua: L360: midiValue 0, origin 2
14:26:48.231 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:48.904 lua: L360: midiValue 64, origin 2
14:26:48.907 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:26:51.237 lua: L360: midiValue 0, origin 2
14:26:51.239 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:26:51.721 lua: L360: midiValue 64, origin 2
14:26:51.723 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:16.295 lua: L360: midiValue 0, origin 2
14:27:16.298 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:17.145 lua: L360: midiValue 64, origin 2
14:27:17.147 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:17.658 lua: L360: midiValue 0, origin 2
14:27:17.661 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:24.804 lua: L360: midiValue 64, origin 2
14:27:24.806 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:25.904 lua: L360: midiValue 0, origin 2
14:27:25.906 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:26.622 lua: L360: midiValue 64, origin 2
14:27:26.625 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:28.574 lua: L360: midiValue 0, origin 2
14:27:28.577 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:29.469 lua: L360: midiValue 64, origin 2
14:27:29.471 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:30.305 lua: L360: midiValue 0, origin 2
14:27:30.307 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:30.672 lua: L360: midiValue 64, origin 2
14:27:30.674 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:31.801 lua: L360: midiValue 0, origin 2
14:27:31.803 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:32.271 lua: L360: midiValue 64, origin 2
14:27:32.273 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:32.946 lua: L360: midiValue 0, origin 2
14:27:32.948 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:35.410 lua: L360: midiValue 64, origin 2
14:27:35.413 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:35.836 lua: L360: midiValue 0, origin 2
14:27:35.838 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:40.472 lua: L360: midiValue 64, origin 2
14:27:40.475 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:40.575 lua: L360: midiValue 0, origin 2
14:27:40.577 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:40.986 lua: L360: midiValue 64, origin 2
14:27:40.988 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:53.045 lua: L360: midiValue 0, origin 2
14:27:53.048 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:53.426 lua: L360: midiValue 64, origin 2
14:27:53.429 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:27:53.778 lua: L360: midiValue 0, origin 2
14:27:53.781 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:27:53.999 lua: L360: midiValue 64, origin 2
14:27:54.001 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:28:02.816 lua: L360: midiValue 0, origin 2
14:28:02.819 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:28:03.315 lua: L360: midiValue 64, origin 2
14:28:03.317 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:28:25.702 lua: L360: midiValue 0, origin 2
14:28:25.705 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:28:26.025 lua: L360: midiValue 64, origin 2
14:28:26.028 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:28:36.926 lua: L360: midiValue 0, origin 2
14:28:36.929 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:28:37.219 lua: L360: midiValue 64, origin 2
14:28:37.222 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
14:28:44.613 lua: L360: midiValue 0, origin 2
14:28:44.616 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 0.0, max 127
14:28:47.753 lua: L360: midiValue 64, origin 2
14:28:47.755 lua: pair 1: control nr 324 (RIBBON X) affects parameter 47, type 0, value 64.0, max 127
I have also had the thought that maybe we are using different firmware versions in our synths. Mine has the latest, which is V1.04.
Which does yours use? You can check by holding down 0, -, and + buttons until the welcome message finishes whilst powering on.
According to an AI search (take it with a pinch of salt), there were five versions, 1.00 to 1.04. The biggest changes were between 1.00 and 1.01. After 1.01, the sysex format was stable.
With your battery low level warning, if you have not changed the battery on the motherboard since buying the AN1X, it may be very old and need changing. The Test mode accessed when reading the firmware version also allows the display of the battery voltage, which should be around 3V. Press the + button one time to see the battery voltage whilst in test mode. My battery is new and reads 3.08V.
An AI search has come up with the suggestion that a permanent low voltage warning, even with a new battery is a bug of the original V1.00 firmware.
