Akai VX90 Editor with Parsing
Thank you for all who worked on AX73 / VX90 editors here so far.
I took what I could and added parsing with the help of AI:
The VX90 (rack version) uses the same firmware as the AX73 (keyboard version). There are a few features (Midi Split point for instance) that (as far as I know) cannot be set on the VX90. So, I would need an AX73 user to confirm that the project reads this information correctly… I disabled the control as I had no way to check if is actually working…
As well, please pay special attention to the dump procedure which must be initiated from the VX90.
I was as well able to get an editor / librarian for MidiQuest Pro made… At the moment that seems to be only librarian for the AX73 / VX90… As I had access to MQ it felt easier than to develop a librarian myself.
