It seems that there is no way to read the current value of a control after it is touched, but before the value changes.
So – if control A was changed from 0 to 17, then control B was changed from 0 to 90 and then if I go back to change control A and turn it one click to the right, I get the value 18, but there is no way in that moment to read the value of 17 (previous state) so I know how much of a change and in what direction.
It seems the only way to handle that now is to save off the value when another control is touched and then read it back when the original control is moved.
Is that correct or am I missing something obvious?
An updated version of the firmware is available on beta. I also updated the documentation, there was a wrong library name mentioned.
@moss the touched parameter of events.onPotTouch is a boolean type now. Not a 0 / 1 number. You might want to check if it works fine with your extension.
