How do I get the current value of a control?
I have a control with id ref#1. How do I get the current value of that control? I do not want to get the value when the control is changed, I know how to do that. I want to get it at any time from any part of my lua code.
If you have the parameter number, at any time you can do:
CurValue = parameterMap.get(1, PT_VIRTUAL, paramNumber)
Check the on line docs for the full meaning of course. Use the appropriate PT_ constant for the type of control you are using.
If you only have the control id, you need the extra steps of
cntrl = controls.get(1)
Pnum = cntrl:getValue(“value”):getMessage():getParameterNumber()
(I think I have that right, if not, with the docs, it will get you close)
Thanks so much. That was exactly the information I needed.
