i connect a mix console to usb host, it is recognized and i can control it.
i can also send midi control messages to a synth at midi Din Out2, it works
when i send command for example to usb device i see the usb flashing at top of sreen and also the midi1 out
the manual say;
One preset may have up to 32 devices configured. All of them can be used at the same time.
i don’t understand how connect ands control more than two devices.
ah yes of course, so it is not real multi midi device. I will go with my mio XL.
for just control devices it would be nice for some users to use usb device out and also use midi din out 1 and 2 without routing/merging usb/din
You can use the 2 midi din ports as well as the USB port (even with a hub, iirc there was recently a question about that) simultaneously, but I use my Mio as well
