[BUG] Editor "Reset NPRN Parameter" resets to "Yes"
Steps to reproduce:
  1. Add 2 sliders to a preset.
  2. On both sliders, set “message type” = NPRN
  3. On 1st slider, set “RESET NPRN PARAMETER” = “No”
  4. Now select slider 2, then re-select slider 1 again.
  5. You will see that Slider 1’s “RESET NPRN PARAMETER” = “Yes” (BUG!)
The state of each slider’s “RESET NPRN PARAMETER” is not restored when selecting NPRN widgets in the editor.
Workround is to try and remember to manually change the “Reset” parameter to “no” again (if that’s what you want) when re-selecting existing NPRN sliders.
