Does anyone has information on how Casio made its sysEx checksums?
EDIT to correct the name of the software
I use software called Hex Workshop In addition to editing binary files and such, you can calculate checksums across a range of bytes using various checksum algorithms.
Thereās only a few ways to calculate checksums, so maybe post a dump and indicate where the header ends and data begins.
I just downloaded it zip file āHexEdit_220_Projectā but Iām on unfamiliar terrain here. Can you get me kickstarted on how to install this?
On my phone at the moment. Thereās an on line hex editor by that name which also can do checksums (I think).
Need to get back to my development computer in a bit to give real answer.
Hex Workshop. The link appears to be legit, but itās showing not secure: www.hexworkshop.com and the download is broken.
Hereās the tool on CNET: Hex Workshop for Windows - Free download and software reviews - CNET Download
I guess old people use old tools. lol
Old tools , yes. But new tools too ![]()
Iām currently reverse engineering the Casio checksum using ChatGPT
No results yet though
simplest answer is to post a dump as an attachment here.
Iāve tried the following 6 types, none of them brought a solution:
function calcChecksum(payLoad) -- calculates a checksum
local result = 0
local type = 4 -- fixed choice of checksum to use
for i= 1, #payLoad do
if type < 4 then result = result+payLoad[i] else result = result~payLoad[i] end
if type == 0 then result = (128-result)%128 end -- roland
if type == 1 then result = ((~result & 0xFF) +1) & 0x7F end-- yamaha
if type == 2 then result = result%128 end -- simple 7bit checksum
if type == 3 then result = (128-(result%128))%128 end
if type == 4 then result = (128-result)%128 end -- 7bit XOR checksum
if type == 5 then result = result%128 end -- 7bit XOR checksum
return result
Here are 5 strings each 159 bytes long, whereby the header is the first 7 bytes and the second to last is the checksum. Each will start with F0 and end with F7. They are as they came from the Casio VZ-8M
- F0 44 03 02 70 01 40 02 01 00 00 08 00 02 00 02 00 02 00 02 00 00 00 00 00 00 00 00 00 00 00 06 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 06 08 02 00 00 04 01 04 00 00 06 03 00 00 08 00 07 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 07 08 02 00 00 04 01 04 00 00 06 03 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 0B 00 00 00 00 00 00 04 0B 00 00 00 01 00 0A 08 07 00 03 00 03 00 00 00 01 01 0F 01 04 00 00 61 F7
- F0 44 03 02 70 01 40 02 01 00 00 08 00 02 00 02 00 02 00 02 00 00 00 00 00 00 00 00 00 00 00 06 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 06 08 02 00 00 04 01 04 00 00 06 03 00 00 08 00 07 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 07 08 02 00 00 04 01 04 00 00 06 03 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 0B 00 00 00 00 00 00 04 0B 00 00 00 01 00 07 08 07 00 03 00 03 00 00 00 01 01 04 01 0F 00 00 64 F7
- F0 44 03 02 70 01 40 02 01 00 00 08 00 02 00 02 00 02 00 02 00 00 00 00 00 00 00 00 00 00 00 06 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 06 08 02 00 00 04 01 04 00 00 06 03 00 00 00 00 07 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 07 08 02 00 00 04 01 04 00 00 06 03 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 0B 00 00 00 00 00 00 04 0B 00 00 00 01 00 05 08 05 00 03 00 03 00 00 00 01 01 04 01 0F 00 00 68 F7
- F0 44 03 02 70 01 40 02 01 00 00 08 00 02 00 02 00 02 00 02 00 00 00 00 00 00 00 00 00 00 00 06 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 06 08 02 00 02 04 01 04 00 00 06 03 00 00 08 00 07 00 02 00 00 04 01 04 00 00 06 03 00 00 08 00 07 08 02 00 00 04 01 04 00 00 06 03 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 0B 00 00 00 00 00 00 04 0B 00 00 00 01 00 08 08 08 00 03 00 03 00 00 00 01 01 04 01 0F 00 00 42 F7
Iim not a programmer myself, so also Github is a bit unfamiliar, but I found these traces to a VZ and a CZ editor. If someone can retrieve the checksum constructor out of their voice edit logic, Iāll set it up in lua and test itā¦
Here is the checksum code
wxByte VZSysex::Checksum(wxByte* pData, unsigned int nSize, wxByte nChecksum)
wxByte nSum = nChecksum;
for(unsigned int nIndex = 0; nIndex < nSize; nIndex+=2)
nSum += DecodeByte(pData + nIndex);
return (0 - nSum) & 0x7F;
wxByte VZSysex::DecodeByte(wxByte* pCursor)
return (*(pCursor) << 4) | (*(pCursor + 1));
and here is the code that validates the Casio sysex header:
bool VZSysex::Validate(bool bFix, unsigned int nSubheaderSize, bool bChecksum)
m_bModified = false;
unsigned int nPos = 0;
m_bModified |= ValidateByte(m_pSysEx + nPos++, 0xF0, bFix);
m_bModified |= ValidateByte(m_pSysEx + nPos++, 0x44, bFix);
m_bModified |= ValidateByte(m_pSysEx + nPos++, 0x03, bFix);
m_bModified |= ValidateByte(m_pSysEx + nPos++, 0x00, bFix);
m_bModified |= ValidateByte(m_pSysEx + nPos++, 0x70, bFix); //!@todo Allow different MIDI channel [0xF0 - 0xFF]
if(bChecksum) //!@todo Checksum created before derived classes run validate
m_bModified |= ValidateByte(m_pSysEx + nPos++ + nSubheaderSize + m_nPayloadSize, Checksum(m_pSysEx + 7, m_nPayloadSize), bFix);
m_bModified |= ValidateByte(m_pSysEx + nPos++ + nSubheaderSize + m_nPayloadSize, 0xF7, bFix);
return m_bModified;
I think I start to see the logic: the checkSum is a standard one , but NOT on the sysEx 7-bit 672 byte payload, but rather on the internal Casio 8-bit 336 byte payload. Luckily Iāve kept both in sync in lua. Need to check further. Thanks youāve set me on a good track ![]()
Yes, that makes sense given your other tests. Just a bit more work on your part.
It works ![]()
Now I can start changing sounds on the Casio
Are you working on the VZ1 (or I guess VZ10M) by any chance? If so I have a VZ1 here I can test with
Yes, indirectly. Check it out here.
I have a VZ-8M, but this preset should for a great deal on a VZ1 or a VZ10 since the sysex is pretty similar. If you care to join, let it be known in that other thread.
I know you have figured it out for the voice patch data, but I found this info on a VZ website from the late 1999s and thought it might be useful to you for the operation memory data part:
There is a checksum on the end of every block of voice patch data (336 bytes) and on the end of every block of Op patch data (100 bytes).
To get the checksum, add up every byte in that block, take the last seven bits (ie MOD 128) then subtract the answer from 128 to get your final checksum value.
