Electra One Mini | Some wishes for a future update
I’m aware that the hardworking E1 team is currently very busy. Days could probably have 72 hours or more – at least temporarily. I’m truly impressed with the E1 Mini. Nevertheless, I’d like to share some suggestions for improvements I’d like to see.
Below, I’ll share my initial ideas for future E1 Mini updates.
A) The values ​​for the new “Rotary Knob” control type could be displayed in the center of the control.
I would like flexible assignment of the label fields. One option would be the current default setting (A). Alternatively, larger values ​​(with more than four digits) could be displayed for the dial type controls below (B).
C) I would greatly appreciate it if the „PAD TOGGLE” control type could be assigned to the switching function of the controller knobs in addition to the rotary function, without requiring Lua programming.
This would make the additional options „DIAL VALUE" and „PAD TOGGLE“ available in the selection menu under “Group Label” in the lower right corner.
I hope this makes sense.
reacting to this and it was also mentioned at Mini - Knob press - #2 by HaPe .
I like the idea and I will try to implement it. It will need some thinking because it introduces something new that current project/preset structure does not support and there are several ways how to go about that.
But as I said in the beginning of the message, I like the idea and will try to make it happen.
Apologies if I missed or duplicating from other discussions - know you guys have been burning the midinight lamp but some additional ideas on the topic after using my Mini ~week:
  • Ability to show a constant / string in Group Label (e.g. show current MIDI channel)
  • Edit of V-fader labels
  • Page reordering (drag/drop in editor)
  • Page copy/paste across presets
  • Set colors with hexadecimal (match DAW / Instrument colors)
  • Device sleep after xx hour(s)
For what their worth… I’m already more productive with my Mini as is, so none of the above has any urgency.
Cheers
+1 along with API access
This is so much more important on the mini since you really need multiple value controls that easily expand to compensate for the smaller display, fewer knobs, etc.
Since we are currently discussing the V-Fader controls, I think it would be useful to be able to assign different MIDI channels to the individual faders.
Any reason why each sub-fader can’t have the mostly the same set of options and API as a normal fader?
That should make it simpler to support as well as a making them more powerful/flexible.
The main reason has been backward compatibility. The original preset format keeps the MIDI device at the control level. The reason is that at the time of designing the original JSON we did not imagine we could ever do something like an envelope with messages spread across several MIDI devices. Also, at that time mk1 featured 256kB RAM - we tried to optimize every single bit and byte. Things have changed and especially now, with vertical faders introduced, it totally makes sense to make it possible to define the MIDI device on the value-message level. I will - most likely - do that so that both control level and value-message level MIDI devices will be supported in the same time, with the value-message taking higher priority in the new firmware. And old firmwares quietly ignoring these. Or something like that.
The very same counts for the labels. So far, each control type has fixed set of labels such as attack, decay, … I will change it so that these are free to edit.
This is what I have eventually done in the upcoming 5.0:
Controls may have events attached. So far, controls had value/MIDI message only. As of 5.0.0, four events are supported: switch-press, switch-release, pot-touch-start, pot-touch-release. An event may send a MIDI message (= parameterMap update), call a Lua function, or trigger E1 internal command (open page, etc).
an example of dial with RPN message and two events that send CC #2:
firing an event does not visually affect the control itself. It can, however, affect other controls and groups in the preset.
Another addition is that groups can optionally track a MIDI parameter in the parameterMap and updated their label / color accordingly. The following picture is an example of group tracking CC #2
so, the control and the group mentioned above allow the switch in the knob to toggle the group label and color:
@hape I hope it is more/less what you needed. It is most likely done differently than you expected, but the benefit here is backward compatibility and extra flexibility.
note:
  • mk2 does not have switches in the knobs, they are triggered with the LCD touch there
  • events defined in the preset always override default actions
it is still beta, more info on that in: Electra One version 5 on beta.electra.one
Thanks so much @martin for this great information. That all sounds and looks really promising. Unfortunately I’m currently too busy with lots of other tasks but a bit later this fall I’ll definitely come back to the E1.
All the best!
