Great!
So, in your example, I was able to isolate the part of the code that controls the CC Sender slider.
portNum = PORT_1
midiChannel = 1
prefix = " "
function sendRevLevel(valueObject,value)
ccNum = valueObject:getMessage():getParameterNumber()
midi.sendControlChange(portNum,midiChannel,ccNum,127-value)
midi.sendControlChange(portNum,midiChannel,ccNum+2,value)
midi.sendControlChange(portNum,midiChannel,ccNum+5,value % 16)
I changed some values, and got the results I expected, so so far so good.
I understan what the portNum and midiChannel do: they define the devices to which this LUA function will send respective MIDI CC. Do I understand it correctly tht “midiChannel” is not a standard predefined command, but just a name used inside this specific LUA script, and could be ChannelNumber or any other word? Same for portNum?
What exactly is prefix = " " for?
Do I understand it correctly, that this string:
is reading the PARAMETER field in a fader’s settings? And if so - how does it know which fader to “listen to”? From which fader to read this value?
I tried to copy the CC Sender fader in your excellent preset and paste it on the same page, then change the number in its PARAMETER field to differ from the original. Both encoders were sending programmed CCs. How do I tell E1 what encoder (what virtual CC value) to listen to?
@kiwigrass , thank you for additional hints in the LUA script, things are starting to make much more sense than before!
The preset commands were very useful! Is there a similar LUA function to send MIDI messages when calling a page within a preset?
prefix = “” was there for another example. If you are building up a string, sometimes you may want to display more than 0-127 (or whatever). The formatter functions are where that would be used. I made a quick adjustment (hope it didn’t break things, my E1 isn’t connected). Turn the polarity or octave control to see prefix used. Again, the name is not great, but you get the idea.
yes - midiChan, portNum and all that are local names I used for those things. Much easier when the script gets big to change it in 1 place (or have the user able to change it with another control) instead of looking through everything and hoping you changed them all correctly.
If you notice,
ccNum = valueObject:getMessage():getParameterNumber() is inside a function called sendRevLevel (yet another leftover name - didn’t have time yesterday to make all this pretty).
and more importantly, when you look at all the controls you see in the function column for the one control the name sendRevLevel. So that control will call that function and that function will read that control’s parameter number and use that as the CC number.
In the old days, if you copied a control it kept the same parameter number and you had to manually edit it to something different. You can see below each control there is a value box and next to is is virtual #16. That tells you the control is virtual and has the parameter number of 16 assigned to it.
If the controls have different numbers, the function (in this case sendRevLevel) grabs the number from the controller when it changes.
The beauty of this is that you only need 1 function to do something and it will ‘ask’ the control for it’s parameter number each time.
There sure is! The lua extension guide has all the relevant info. You can tell the E1 to go to specific page (maybe use a momentary button, or a list if you want to select from several pages) and on entering the page to do stuff. Lua extension | Electra One Documentation
I use this function a lot:
pages.onChange(newPageId, oldPageId)
A callback function that runs automatically when the user switches to a different page. The function is called only if Page change notifications have been subscribed to.
For example:
events.subscribe(PAGES)
function pages.onChange(newPageId, oldPageId)
print ("old: " .. oldPageId)
print (“new:” .. newPageId)
You could condition what to do if the newPageId is 1, or 2, or 3 etc. See my previous example for the if x then y logic.
You can use this function to change the currently displayed page
pages.display(pageId)
where pageId is a numeric identifier of the Page (1 .. 12).
But again, the lua extension guide is your best friend.
The Lua extension guide is my go to reference for sure. However, for ‘new to Lua’ folks it can be frustrating.
Experienced programmers know they need some particular function, so we scan the guide for the syntax.
New users want to do something, but they don’t know what they are looking for so scanning the guide is very hit or miss.
That’s why small, specific example presets are so useful. It gives the framework for a task. Once they understand the simple and can start modifying it, then the guide becomes essential.
Agree. As someone who came to this with limited programming experience the lua guide was very useful though IMO. If I wanted to do something when I change a page I would look at the guide for things in the pages and page section. And then ask your advice when my code didn’t didn’t work as expected. So my suggestion is a blended approach - examples and the guide. After 4 years I still use that approach. The guide contains examples of some of the functions use which is also very helpful.
Thank you all so much!
First, by using parts of the code from your examples, I was already able to achieve a lot of what I wanted to achieve, so this is a great start!
Second, I will definitely study the LUA Extensions guide. I agree, it’s not the easiest topic to digest for someone unititiated, but I will do my homework first, and then, if I need expert advice - I know where I can find it. What a great community here, can’t say enough how grateful I am to your assistance!
Hi! Me again ))
Those two examples that you kindly provided to me, were really invaluable!
Spent a couple of evenings reading the LUA extension guide and exchanging some mutual accusations with Google AI ))), but after those couple of evenings I learned how to:
- Target a specific control on a page
- Listen to and actually use the capacitive touch events (I managed to toggle a pad touching the control!))) Was very proud of myself!)
- Send multiple commands from the same control
- Change its color depending on the value
- Display custom text overlay for value ranges
This 0.00001% of E1 capabilities already gave me like 500% more convenience, customizability and usability compared to any other MIDI controller I owned.
Once again, thanks for your help and for pointing the right direction for me! I am sure I’ll come back with some more questions, but for the time being I will focus on making a couple of presets myself, and see how it goes.
great to hear about your progress. That’s the way this community has been built.
New folks come in, ask questions, learn, and then start helping others.
It’s one of the finest examples of how a user forum is supposed to work that I have ever seen.
OK, dear community, with your excellent help and some torturing of Google AI, I created a preset to control Kinotone Ribbons - an incredibly deep pedal with so many features that mastering them all without a strong visual help can be really hard.
This is where E1 came in so handy!
I will post a link to this preset (it is far from being finished, but it does not crash, which is areadly great ))) to ask a couple of technical questions the AI failed miserably to help me with. I’d be very grateful if someone could share some thoughts or point me in the right direction.
My first question is as follows. I managed to trigger a toggle pad with a capacitive touch of one of the encoders. It works very nicely, but my script (or shall I say the AI-proposed script that finally worked) has one problem: the capacitive touch action triggers the pad toggle action even if the row in which this pad is located is not currently selected. In other words, even if I twist the encoder to control a fader elsewhere on the page (or even on a different page), the pad is toggled.
Is there a way to somehow isolate the capacitive touch triggering to only when the control is a) on a current page, and b) in the currently selected “row”?
The control ID that is being toggled by capacitive touch in my scrip is #8, and the encoder ID is also 8 - by pure coincidence!) (second from the left in the lower row of encoders).
I have a gut feeling that my function that triggers the pad toggle is a bit too global, but I am not sure how to make it more local.
Thank you in advance!
Yes. It is too global. Since you only want the pot touch event to apply if both potId = 8 AND controlId = 8, try this
if touched == true and potId == 8 and controlId == 8 then
Cheers
Thank you!!! It seems so simple… when you know what you’re doing))) Not yet my case. Works perfectly now!
But now I have another question: let’s say, in my preset, I have the bottom row of controls comprising only buttons (toggle and momentary pads, using E1 terminology), that I am intending to activate via the touch screen.
Is there a way to tell E1 not to toggle these pads by encoder twists?
I don’t know off the top of my head. I have never tried that.
Looks like this is a tough one. AI failed to propose a viable solution to me ) Unless there’s a simple trick that @martin knows )
And I have the next tough question, where AI failed to help me as well ))
Is there a way to change the NAME of the control (Fader in my case), depending on which of the Toggle pads is toggled ON? So far I wasn’t able to do it, and used the custom text overlay. This works just fine, but I feel I am wasting the valuable screen real estate with a generic fixed name for those controls.
AI was trying to explain to me, how difficult it is because the NAME is somehow “hard-coded in JSON” or something like this. I am not knowledgeable enough to agree or disagree.
Yes to the 2nd question. I will try to make an example today.
Take a look at this preset built by @NewIgnis for the Pro 800 synth Electra One App . If you touch the “SYNC” toggle pad on the VCO page you will see the name displayed for the “OSC A Freq” and “OSC A Vol” change. The “SYNC” toggle pad calls the function syncOnoff – you can see that if you look at the layout info for the “SYNC” parameter. Here is the lua code:
function syncOnOff (valueObject, value)
local nameCtrl = {4,174}
local ctrlName = "OSC A VOL"
if value ~= 0 then ctrlName = "SYNC OSC VOL" end
for i = 1,#nameCtrl do
controls.get (nameCtrl[i]):setName(ctrlName)
local nameCtrl = {58,112}
local ctrlName = "OSC A FREQ"
if value ~= 0 then ctrlName = "SYNC OSC FREQ" end
colorVco1(valueObject,value)
nameCtrl are the Ids of the controls whose names are going to change (In this case there are two parameters whose control names are going to change and there are 2 control Ids for each parameter because each parameter is on 2 pages). The Off value for the SYNC pad is 0, so the name change happens if value ~= 0.
ctrlName is the name to be displayed depending on the value of SYNC. You can adapt this function for your application (you can ignore the call of the colorVco1 function at the end).
Cheers.
Thank you, will experiment tonigt!
One question: am I correct to assume that nameCtrl is the standart LUA extension and has to be called this and only this, while the ctrlName is the local function name that I can tailor to my needs, like fader1name etc?
They are both defined locally (to the function). There is a certain logic to the naming used, but you can call them whatever makes it relevant to you.
