onPotTouch | If the recommendation from the Lua messages is followed, the function will not work
I get the following error message:
17:37:46.693 onPotTouch function will be deprecated. Use onPotTouchChange instead.
If I simply replace “onPotTouch” with “onPotTouchChange” it immediately stops working. What “magic” is additionally required to maintain the functionality?
The developer guide has a typo (cc @martin) , it returns the touched PotId in range 1-12 (for E1 Mk 2), assume this is in range 1-8 for the Mini:
I have used this print statement in the event handler before to help me debug:
function events.onPotTouchChange(potId, controlId, touched)
  print ("potId: " .. potId .. ", controlId: " .. controlId .. ", touched: " .. (touched and "yes" or "no"))
  doStuff(potId, controlId, touched)
Oh and don’t forget to set up the events subscription in your preset’s preset.onReady() callback handler:
function preset.onReady()
   events.subscribe(POTS)
Thanks so much @Phommed for your response.
I also recognized the typo as I was looking into the API-LuaExtension. I inserted your print statement and it showed that everything seemed to work accordingly - as long as I used the “old” term “onPotTouch”. As soon as I changed it to “onPotTouchChange” it immediately stopped working. But the print statements still looked good.
I was about to give up because it worked at least but comparing both versions with your print statement solved the problem.
The previous term “onPotTouch” counted the Pots from 0 … 11 (on the MK2). The new term starts counting from 1. :roll_eyes:
Thanks again and enjoy the rest of your weekend!
I fixed the Page vs Pot mistake. Good point about 1-12. I need to come up with some general way to address this everywhere where there is a difference between the Mini and the OG mk2.
And in general stick to one way of enumeration everywhere: either always start at 0 or always start at 1. (Eg also bank, slot index)
There is a bit of a hassle here. Lua uses 1-based indices, while in SysEx I stay with 0-based. I am trying to stick to that rule. eg, the change of onPotTouch was primarily motivated by making that Lua function inline with that. Not that I like it, but it is how it is now.
