Performance page, control reference
Hi @martin - on the performance page (when in Edit Mode) you currently CAN NOT long press a simple control reference to change what it controls. That DOES work for the Macro Controls: it then brings up the same menu as when you create that macro.
When I do long-press a control reference (to change its controls or to even erase it) the screen goes sort of ‘empty’. I guess this is still a bug.
** What would be amazing is if SNAPSHOTS could also be implemented on the performance page..
* Also - when selecting the ‘pipe’ as a mode within a macro: is it correct there still isn’t a plug-and-play LFO preset anywhere that can be assigned to control an element in another preset (like the manual describes..)?
Thanks!
It is resolved now.
Recalling a snapshot? Pls elaborate it a little bit more.
The Send LFO preset is an example is a simple LFO that sends its output to the datapipe interface. If you pin that preset so that it runs in background, the performance pages of other presets of should list that pipe when creating new macros. Pls note, there is still a lot to improve on this.
