Is it possible for presets to speak to eachother? I’ve made an LFO preset that sends out CC values but it would be very cool if it could target and modulate controls on other pinned presets.
Yes, Martin has foreseen a ‘pipe’ mechanism. I haven’t worked with it myself, but this would allow using the values of an LFO preset or a sequence preset as input to another preset.
I think this is a link to part of it.
Sounds interesting. Totally beyond my ken though, unfortunately, but I shall keep an eye on it!
a lot has been done to make it more friendly. A quick start instructions:
Preset that generates modulation:
Take a look at preset Send LFO. The important bits are local pipeOutput = pipe.acquire("output"); and pipe.send(pipeOutput, lfoTriangle);
the acquire creates a communication pipe called output. The send() function that writes data to that communiation pipe. Note, the preset does not send CCs or anything like that. It sends a stream of numbers to the communication pipe.
Tap “RUN” pad to active the LFO and pin it, so that it runs even when you leave the preset.
now, the receiving part:
- create a new preset with one fader control in it. Leave the default name “FADER” there.
- swipe the screen on the left side to open the Preset Menu window
- tap EDIT MODE to enable editing the preset (performance page only now).
- go back to the preset page
- open the "Page selection and tap PERFORMANCE button. The Performance page will be opened with 36 placeholders on the screen.The placeholders can be used to add/edit controls and macros.
- long touch the first placeholder
- tap “ADD CONTROL REFERENCE” button
- a form will show up, just confirm it with “Add control”.
- you will land on the Performance page and you will see there the “FADER” control you created earlier. If you switch between the Performance page and the Page 1 you will see that it is the same control.
- long touch another placeholder on the Performance page
- tap “Add macro control”
- you will get a form to add a macro control. A macro control allows you to modify and modulate values of preset controls.
- tap “Add control”
- change mode to “Receive pipe”. If your LFO preset is running, the form will be automatically prefilled.
- tap “Macro fader” in the top-left corner
- tap “Save changes” in the right-bottom corner
you should be now back on the Performance page. There should be two controls: the “FADER” and the “New macro”.
You can use “New macro” to adjust modulation depth of the “FADER” now. The “FADER” should indicate the modulation using an animation.
I will add screenshots here when I have a moment…
I think I might create an LFO preset based on the one I’ve made as extension to the Minitaur. Would be fun to use the same LFO types like ‘echternach’ and ‘trapezium’ on multiple synths in sync with MIDI clock ![]()
Looking forward to trying out the pipeline stuff, thanks @martin
@NewIgnis definitely think the preset library is lacking a good LFO. I can share mine as well but I expect your code will be far more efficient than what I wrote with ChatGPT!
@martin the method you described is working well except once the macro is set and running it seems you can’t change the rate of the LFO anymore. It seems to default to a set rate the moment you tweak the rate knob
Currently, you need to go back to the LFO preset and adjust the rate there. I’m looking into ways to make this easier, and I’m open to any suggestions.
That’s what I’ve been trying when I get the behaviour described above. The rate on the LFO preset itself seems set once it’s assigned
@martin how many lfos are reasonable using datapipes. Is 16 realistic. How is the midi control using the remote knobs page in settings best applied. I like that you can quickly link to external midi lfos but I don’t know how to link them to presets or to the performance page after the knobs are defined. I like the pull down menu on the performance page because it feels like a mod matrix but I wish I could select mapped knobs to modulate the macros on the performance page.
I just wanted to say I finally spent time with the performance page and with using remote knobs and it is a terrific feature. I’m not sure if the current documentation does it justice but after using the 16 steps listed in the message posted above it made more sense and I linked the performance page to 16 external midi lfos and it’s a joy to use midi learn in settings and get the remote knobs put to use. Between remote knobs, performance page, snapshots, and captures its a great deal of functionality and a little difficult to get your head around and I can’t help but think if I had a better understanding of them I could make even better use of the E1. So much to learn. I think seeing tutorials and use cases in the documentation would go a long way.
Have you come across the issue I had where the LFOs are stuck on a particular speed once linked? See above for details…
No sorry I haven’t experienced that but I’m mostly using external midi lfos with remote knobs.
