Here’s another one for the Arturia collection; Buchla Easel V.
I’ve added two extra rows of pads which can be used as momentary switches. One row (xM+) goes up when you hold the pad, the other goes down (xM-) when you hold it. It gives some nice playabilty over the sequence which you don’t have when you play it with a mouse.
https://app.electra.one/preset/DTAudJjZcmJKSIW1lTh6
Mapping file is here, remove .pdf from the extension and you’re ready to go!
Arturia Buchla Easel V Electra One.mexmidi.pdf (7.1 KB)
@SmartBits, is this mapping file the config I need to import in the v-collection software? Was going to build one of these for CS80-V (unless you are already planning on it, hehe).
Indeed, if you go to the Advanced settings (the cogwheel) > MIDI > Right click on “MIDI config” > Import
I’ll take a look at the CS-80.
haha thanks! your work almost singlehandedly will cover all my v-collection needs I think
Haha, good to hear! CS-80 is about halfway there. It seems like this is a bit older plugin than the other ones in the V Collection. It takes up bit more work than I expected. But I’ll probably have it ready in a few days.
Will happily wait, oh v-collection master!
I think Arturia should give me an endorsement deal.
