amazing, just came in to look for this today! thank you so much.
I’ve just integrated the SE-02 into my live setup and am struggling with the fact that it doesn’t have a knob “pick-up” mode like many synths with presets. does your template update when you load a new preset on the synth? is that related to the sysex patch request feature you mention is missing?
Unfortunately it is indeed the SysEx I need to provide a template update.
This being said, I still completed this Preset with all patch functions because I found it quite inspiring when playing the SE-02, even without the template update.
I looked around but I can’t find the Sysex implementation chart , especially the parameter table for the patch dump, for the SE-02. That one is vital to be able to get you your pickup mode.
If anyone has it . Or cares to reverse engineer the said table?
I couldn’t find it either.
There is a software editor done by SE themselves, I looked into the manual and there’s no implementation detailed there either.
I will try to ping somebody at Roland. I think it is quite a pity they do not publish sysex implementations for all their gear. It is weird especially for them, because they often provide extra functionality/parameters over the sysex…
worst case is someone takes the time to stick a MIDI Monitor in between the SE-02 editor and the hardware and captures/maps out everything being sent and received.
Roland in the past has been very helpful when I contacted their service centers for parts, manuals, etc. Not sure what they are like today though.
I have the SE-02 editor from Studio Electronics, so I thought it might be worthwhile monitoring the traffic going on between the two of them. The editor only finds the SE-02 via USB, any one has an idea how to intercept USB MIDI data from editor into SE-02 (MIDI thru won’t work, I tried that, but the editor won’t connect with the SE-02 if midi thru or MIDI echo is on)? I’m pretty sure it is MIDI !
The other way round is easier, by monitoring what came out of the DIN MIDI OUT of the SE-02.
Here’s what I found: if the editor requests a patch from the SE-2 , the SE-2 responds in 4 chunks:
3 times 78 Bytes, and one time 62.
The header starts as follows F0 41 = Roland 10 = Device ID (if the SE-02 follows Roland standards) 00 00 00 44 will be the Model ID SE-02 (Roland typically adds one or more 00H’s in front of the Model ID to ‘differentiate various things’ (found in D-05 MIDI manual) 12 is usually a Roland command ID (DT1) for transfer while 11= RQ1 is the counterpartner for Request.
So my guess is where are indeed looking at a data transfer where shortly after 12 is the body , consisting of an address then data and it ends with a checksum.
When the SE02 editor is finding the SE-02 for the first time, this is what the SE-02 responds :
Last check: retrieving the first patch of the first bank, for which I know it is called INBOUND . I believe the names to be 16 digits long. The name is in the second to last row: 49 6E 62 6F 75 6E 64 and a bunch of zero’s stand for “Inbound”
I have a new challenge here: the transmission in the Roland SysEx does not correspond with the transmission of the CC changes.
An example: SysEx transmits VCO1 range as a value between 0 and 5. But the CC controller 16 for the same purpose transmits the values 0,25, 51, 76, 102 , 127. Is there a clever way I can have the SysEx values correspond with the order of the items in the control list, rather than with the value I gave to each list item?
Any other ideas?
How I can best correlate 0 into 0, 1 into 25, 2 into 51 using the patch editor?
In other words the received 0…5 from the 3 bits of byte 62 need to get converted via stretchValues() and the resulting 0…127 is to be stored in parameterNumber 22.
How do I construct such json syntax in the responses section?
(By the way @oldgearguy, thanks for the tip of monitoring the traffic between SE-02 and its editor. I overlooked it the first time you suggested it, but subconsciously I think you planted that idea in my head anyways)
Hi, I’ve just implemented patch parsing on the SE-02. It now should retrieve the settings from the SE-02 if you use the ‘patch request’ pad, or the left upper button of the E1. This is the “pick-up” mode you were looking for.
Be aware: only the fader controls should work fine for now. The list controls will change also but retrieve the wrong value from the patch request as yet. I need some more feedback from the guys on this forum before I can mend it.
@moullinex Can you try it out? It should drastically improve smooth sound transitions when playing live.
