My preset for Triton has a bunch of controls with negative values as I had mentioned in an earlier thread. When I send parameter change for these, I need to split the negative value and send it in two bytes like below:
"42",
"type": "value",
"rules": [
"parameterNumber": 1
"50",
"41",
"03",
"00",
"2A",
"00",
"03",
"type": "value",
"rules": [
"parameterNumber": 353,
"parameterBitPosition": 7,
"byteBitPosition": 0,
"bitWidth": 1
"type": "value",
"rules": [
"parameterBitPosition": 0,
"bitWidth": 7
Here, 353 is the current parameter number. While this works fine, it is a lot of manual effort to refer to the right parameter number in each sysex data (I have dozens of these). It would be super cool if there is a way to refer to the current parameter number or just leave it blank for the system to understand I am referring to the current parameter number (latter preferable, of course). That way, I just need to copy paste the same JSON on each control that supports negative values.
Alternatively, if I can do this in Lua, that’s awesome too
