I’m looking to emulate the Roland S-1’s “Shift” workflow. When a user holds down a Shift button, turning a knob controls a secondary parameter.
The issue is the primary and secondary parameters often use completely different value scales and string formats.
Is there a way to dynamically swap a knob’s formatter, or push a custom string format/overlay via a script when a Shift button is enabled/on?
Appreciate any insights
For sure, but it takes some structure. Check out for instance the last version of the Micro Q I made, and have a look at the effects section: any time you change the effect, controls appear and disappear, change places, get different colors and names, have a different range and get a different overlay assigned. You could do similar by get 2 states, one with and one without shift.
Many thanks will take a look - much appreciated
Many thanks to NewIgnis for his code assist.
Sharing sample code here - always seems simpler after you step away for a bit;
-- dB Overlay
local dbOverlay = {}
for value = 0, 127 do
dbOverlay[#dbOverlay + 1] = {
value = value,
label = string.format("%d dB", value - 64)
overlays.create(OVERLAY_DB, dbOverlay)
-- Waveform Overlay
local waveOverlay = {
{ value=0, label="Sine" },
{ value=1, label="Triangle" },
{ value=2, label="Peak" },
{ value=3, label="Random" },
{ value=4, label="Ramp" },
{ value=5, label="Square" }
overlays.create(OVERLAY_WAVEFORM, waveOverlay)
…then apply as needed. The string.format was tripping me up.
