I started this with the idea I needed to quickly access the nested or shifted functions on the P10’s front panel space. After I finished with this part I also wanted to be able to edit stacks using the front panel for the A voice and the Mini as the UI for voice B. This appears to work! Yay! But I will need time to test it. If you download it you will be testing with me. Its mostly feature complete. I would like to say I did all the coding. But I did none of it. Claude did all the heavy lifting and I did all the stupid human stuff. Let me know what you think if you have a Prophet 10 Rev 4. PS: I also wanted to try an AI assisted project. I am surprised how easy it was. Start in small chunks and add slowly doing lots of testing. This is was also a test of 5.0.
Dave
