Running 3.5 on a mk II.
It appears that the set/get overlayId stuff is broken. (Unless my syntax is not correct)
I can set it using:
i = 99
val = controls.get(ctlId):getValue("value")
val:setOverlayId(i)
but when I try to read it using code similar to:
j = val:getOverlayId()
the value always comes back 0
This can be a lower priority – I rewrote the PCM 80 template to not use the overlayId field in the control/value.
Not fully debugged the change, but 90% looks good so far.
busa
3
Seams as the whole Overlay is buggy. also the overlays.get (overlayId) command does not return a valid Overlay-Object.
martin
4
@oldgearguy I really have hard time to reply to that one
I reviewed both calls, set and get. It works as expected
Here’s a preset inspired by your code: Electra One App
This is correct though. Just fixed it in the development version of the firmware.
