UPDATED Behringer WAVE EDITOR
BASIC WAVE CC’s and NRPN Editor. SYSEX Request mapped to most functions. Most Control values have format functions implemented. Other improvements made and cleaned up.
Some notes: The Behringer Wave only sends sysex out the USB port.
Many Program page values cannot be requested with the Patch Buffer dump which is what I am using.
Group B controls are missing. For now use the WAVE panel controls for Group B sounds and the Editor for Group A. (a bit later..This is workaround is proving not to work reliably. I will give it some more thought.)
I am certain there are other missing functions, drop me a note for layout suggestions and how you may like to see Group B controls added.
Dave
I have updated the editor slightly and discovered something I am not sure is a bug.
The buttons and their functions are “fiddly” when they redraw any text or graphics. They mostly work.
But this could be related, I am using 2 buttons that are adjacent to the Menu and Context button. I am setting the visibility of either button depending on the Wavetable dial selector. When you set the value to lets say 31 the Upper wave table button should blank (and it does) and the sample length button should appear (it does). When this happens the context and menu buttons disappear. You can still press them and they function but when you do it sets both the upper wt select and sample length to visible.
I have played around with it and gotten no where so I am asking if it could be a bug.
Above is the current version with the bug.
Thanks for looking.
dave
Some of the visual errors go away when I changed the group variant parameter to default rather then “Highlighted”. Still some corrupted characters appear occasionally as buttons are pressed but no longer as ugly.
Slightly updated version here.
Updated the Behringer mini preset.
Based on my original, mutated by Claude and still beta. Added support for Wave Firmware. 1.5.0
There are some functions that require sysex as opposed to CC’s. You will also note the odd way you have to switch layers. Its almost better to use the mini interface to edit layers but if you want use the front panel at the same time as the mini’s interface (Layer A on the wave front panel, B on the mini). Real time tweaking it might glitch or skip values if you turn knobs to fast. There is a switch on page 7 that sets the gap time as you switch between layers in this mode. Looking for away around it. Taking a break to see how I would really use the wave and mini together for improvisation.
dave
