Hi, this is a major improvement over the previous 1.6 version for 4.0.
Some things to note.
On the Microwave under device parameters set midi overflow to link.
BUT do this with the Mini’s midi in blocked somehow. (Unplug the midi out from the uwave is the simple way.) Do this because the uwave when switched to Link sends a tremendous amount of data that seems to create a midi loop. It takes 15 seconds or so then reconnect the midi out to the uwave.
Now if you change a value/patch etc, it will update the mini’s preset. Basically it syncs the 2 devices.
I am certain there are errors somewhere. I have done my best to check it all out.
This was based on my patch that I hand entered with the web gui then gave to Claude.
Hope you like it. its the most feature complete editor I have seen.
No Multi mode yet.
The performance page are my initial ideas on grouping controls.
Thanks
Dave
