I have problems with the Filter Envelope Mode and Filter Envelope Trigger parameters.
When I look at the picture it looks like Mode uses bits 0,1,2,3,4 Trigger uses bits 5,6.
My question is, how should I set the values ββin the following images?
@Electrolove I must have worked my way through the same questions when I built my Blofeld preset. Maybe it could help you for some inspiration? Check it out.
