In my preset with patch request for the OB-6 I 'm setting up 2 requests, the regular patch dump request and the globals dump request. Both go wrong differently.
Issues with the patch dump request:
What is good:
- I manage to trigger the request
- Via my MioXL I see the request being responded by the OB-6
- Via MIDI-OX I see the response returning to the E1
What is not good:
- On the E1 the MIDI 1 IN does not light up.
- On the E1 patch editor the SysEx message does not appear
Why is this message disregarded? Be aware the response is 4*256 bytes and one time 152 bytes long.
Issues with the globals dump request:
What is good:
- Via controller with parameter 1126 and function “globalsRequest”, I am able to fire the request
- I see the OB-6 respond in Midi-OX:
- On the E1 the MIDI 1 IN lights up for this message
- On the E1 patch editor the SysEx message does appear
- Look at byte 4: it has value 1 assigned to clock port param 1028
The control has value ‘USB’ assigned to that control:
- And indeed the OB-6 has that same value.
What is not good:
- If I request the globals dump, all the aforementioned happens, but on the E1 itself the control keeps showing ‘DIN MIDI’ which corresponds to the value 0 ???
The same happens with some of the other controllers.
But when I turn those knobs on the E1, or I change the global values on the OB-6, both instruments nicely sync.
What am I doing wrong? Why is it the SysEx is well received, correctly assigned to controllers, but then incorrectly represented on the E1?
