When Electra One App receives a patch dump, after having sent a patch dump request, the Electra One freezes.
The symptoms are the same whether the dump request is fired with the upper right button, via a midi SysEx request in lua, and while or while not the editor is in listening mode.
Via MIDI-ox I nicely see the request being created, and the A-station responding, but then the E1 freezes.
Weird thing: it used to work, and I did not change the parsing. But since I can’t make the parsing made visible anymore in real time in the editor, it’s kinda difficult to find the cause.
When I send the message using the USB MIDI convertor, ie. E1 receives that via MIDI IO DIN, the controls get updated and the mk1 controller does not get stuck.
I guess it must be something with timing or message looping somehow.
Edit:
tested with your A-station NIG V2h preset. I just gave it a try on mk2, works fine too.
