Hello all! Im new to the Electra one and Im using the preset in the library for the hydrasynth (Electra One App) and it worked well once I plugged in the usb cable to the host port. However when changing presets on the hydrasynth, control values aren’t updated on the Electra one even though I am seeing midi data come in on the monitor. Is this normal? is there a way to implement that functionality?
Are you using NRPN?
Yes, I am as I believe thats how the preset was setup
As far as I know, Electra will only set CC when changing parameters on the Hydrasynth panel. Not NRPN. I just asked Martin for that feature.
Copy, I wonder if there could be come kind of work around that when program change is received by the Electra you could change to a different snapshot possibly?
I can’t answer that, sorry. Maybe someone on the forum can help?
