Hi there, how do you remotely set up the Preset ?
This seems to be lacking the info : External MIDI control | Electra One Documentation
I think you need to upload a config file using Electra One App
Haven’t tried it yet.
@martin could you perhaps give an example how to use midiMessage: control change (CC) or program change?
Below I got from Martins github: [electra.one/midicontrol.cfg at master · martinpavlas/electra.one · GitHub]
The first entry is to switch a Page to page 1 with midi note 36.
The rest event names are well named and it should be obvious what they do. switch to the next page, a specific page, a specific preset or the next preset.
"event":"switchPage",
"eventParameter":1,
"midiMessage":"note",
"parameterNumber":36
Here is the full file [midicontrol.cfg] .
Edit it to your need and give it a try.
"version":1,
"midiControl":[
"eventParameter":1,
"eventParameter":2,
"parameterNumber":37
"eventParameter":3,
"parameterNumber":38
"event":"switchPageNext",
"parameterNumber":39
"event":"switchPreset",
"eventParameter":1,
"parameterNumber":48
"event":"switchPresetNext",
"parameterNumber":49
"event":"switchPresetPrev",
"parameterNumber":50
I found this info in the dev documentation helpful:
https://docs.electra.one/developers/confformat.html#top-level-objects
To use CC 7, Value 1 from the CTRL port just type:
"midiMessage":"cc7",
"parameterNumber":1
To use a program change 1 from the CTRL port:
"midiMessage":"program",
"parameterNumber":1
See also this thread:
hehe, I was writing a message about that
but just discarded it.
Yes, that that thread describes how to upload the config and the document @studiobischof mentioned provides full info on the Configuration file format.
Ja, edited my half baked reply
Thank you !
It seems easy to get it working. (although, that could be much more user friendly to set this up from the web editor)
