Optional indeed, please
Can such options be set through a SysEx command? Then the remote script can make sure the setting is correct.
P.S. it would perhaps be good then any case to ensure that presets maintain their CURRENT state, so that people can actually switch between two presets.
The first Lua execute call is missed on Electraâs side
remote script:
Electra:
I am looking at thatâŚ
Perhaps I could/should add a small delay, to ensure that loading of the preset internally in the E1 has settled before sending updates?
Let me first check what is happening. Maybe I can tweak it on my side. That would be better way to take.
I tried to load all public presets to fw 3.0. Everything seemed to work fine but Access Virus from @joris.roling. I will review what is happening there. If I remember that correctly, it is quite a complex preset.
Canât remember what you are responding to ![]()
Maybe i can help with that virus preset. Yes itâs big!
But I tried latest beta, but Iâm getting a lot of rogue CCâs after startup or preset changes. Also the device seem to crash when switching presets via touch knobs.
This I tried with a private preset, should I share it with you?
The messages are actually ok. l mentioned that earlier today. They will not be there eventually, but it is an intended thing.
please share it with me.
I was not response to anything
I just wanted to see that all public presets can be loaded. I had troubles with that oneâŚ
This should work now tooâŚ
Martin - when I have more than 2 free minutes, Iâll check it out.
I have so many projects half-started and right now, family and work has sucked up every second of my days.
I hope things in your world are going as well as possible.
Thanks for putting so much effort into reworking and expanding the entire Electra One environment.
It has been a pleasure to use it and watch it mature into this excellent platform for external control and more.
(E1 projects: tc 2290, finishing the Alesis Micron, Symetrix 606 started, Waldorf XT partially started, plus making daughterboards with an Arduino + CD4066âs to add MIDI control to Schrittmacher sequencers, consulting on a new hardware sequencer, beta testing for Conductive Labs, and sometimes even just sitting down and playing a synth or twoâŚ)
I need to retire so I can get more done.
lol
3.0-a.13 is available on beta.
I checked everything and made a few adjustments. I still miss the first Lua execute SysEx message. Adding extra sleep before calling _mixer_controller.refresh_state() resolved that. I need to review it more. For now, this extra delay fixes that. @jhh would you take a look at that?
Default values are not send when the preset is loaded.
Changes:
- tried to improve layout and visual of the screens
- redesigned the bottom info bar. It uses bigger font now and shows information about used RAM and allows users to add a custom text (see bellow)
- it is possible to use a lua function to display a custom text in the right part of the bottom info bar. eg.
info.setText("Hello World"). The text is limited to 20 chars. - fixed a few issues with electra locking up when changing pages, presets, etc. There is still work to do.
For those who have troubles with web update âŚ
firmware-3.0-a.13.img.zip (306.2 KB)
I added a short delay to fix the issue for now. (It is a bit strange because actually the remote script first updates the return track names and only then the normal track names. But perhaps the issue is that the normal tracks are actually visible on the E1 and the return tracks arenât.)
Excellent! Thanks!
As soon as the documentation is updated I will try to see whether it is possible to send the actual values Ableton reports for parameters as strings to the E1 (which would solve the issue that the values for complex paramaters like Volume faders or frequency ranges as displayed in Live do not exactly match the values shown on the E1).
That message disappears as soon as you change preset.
Also, what exactly is the used RAM indicator showing? When changing presets it also changes: with large presets it is a few bars wide, with small presets no bar is shown at all.
That is intended. The idea you can add your own text there in the context of given preset. eg. patch name (that is actually where the idea comes from). If the text was left there after the preset change it could easily become invalid - yet staying on the screen.
If you are asking because you would like to maintain some âstateâ across the presets - I am thinking about how to do that.
it is showing percentage of used memory out of all memory available for a preset. ie. no white bars, = close to none memory used, white bars only = memory fully utilized.
I am not sure if this will stay there till the production release. It makes my life easier now when testing public presets and and reloading presets frequently.
I am still puzzled too. Your part of the software sends the messages after it receives the âpreset switchedâ confirmation. I send that one, when the preset is up and running and Electra is basically idle.
I will be travelling next week. I will not be able to do any serious programming. I will work on the docs instead.
I am going to be away for three+ weeks after next Saturday July 16.
Have a look at replace __generate_6_char_string with adjust_string (was str_for_value) ¡ Issue #55 ¡ markusschloesser/MackieC4_P3 ¡ GitHub, might be helpful if I understood correctly
Thanks. To be honest I donât understand what Live.MidiMap.map_midi_cc_with_feedback_map
does; in particular what does the feedback rule do?
Not sure it is relevant though for what I need, which is a LUA command implemented by the E1 that accepts a string as parameter and uses that as the value to display for a particular control.
Yup, I know. I am about to add it but I have need to understand it a little bit more. It is quite easy to overwrite the visible display value (ie. what you see on the screen). But how about the underlying midi value? I assume you will still use it for the communication with the Ableton, right? And will the, eg. fader value bar, be set correctly? Or do you need a relative control where the fader does not maintain its internal value and just sends increments/decrements to the Ableton?
