Generic MIDI MINI
A simple preset, generic in use for any instrument, to control most common expression CC’s:
  • Volume
  • Pan
  • Mod Wheel
  • Expression pedal
  • Breath Controller
  • Glide/Portamento
  • Sustain pedal
  • Sostenuto pedal
    Page 8 serves to set the Device’s MIDI channel
I have been trying this out, nice. The MIDI channel control mapping is not quite right:
1→1
2→1
3→2
16→15
I have tried editing the list values, but no matter what I put in, the behaviour always stays the same as above.
Thanks for noticing.
It should be okay now
All values give channel 1 now. I have checked the output channel by monitoring on both MIDI-OX and the monitor on my MRCC.
That is really weird. On my MINI i get 16 different values…
Let me connect it again…
Load it again please. It worked as expected.
I now added also a Port setting on the Device Page, and a monitor down right showing the actual DIN MIDI Port and Channel it should transmit on.
Perhaps you transmit via USB ? I did not test that
yes, USB Device port for transmitting.
It is working now with the correct channels being transmitted. Cheers!
