all my graphics appear glitched out on every page. tried both resets and a variety of usb cables but no change. am able to update firmware and load a preset from the web app but can’t try going back to 1.5 as the server appears to be down.
Wasn’t there someone here recently who had the same problem? Maybe try a search, if what I am writing below does not work.
Iirc it’s the new macbooks not delivering sufficient power over usb.
Can you try with a powered USB hub?
press and hold the left-middle button when the boot up animation is active (this will format the internal SD card). The button must be pressed when the animation is in progress and it needs to be held down until the animation is completed.
disconnect and connect electra again
send enclosed sysex file to Electra Controller CTRL port - uitoolkit-1.0.0.syx.zip (206.7 KB)
if you have done everything correctly, Electra should start up with all graphics assets recovered, Now you can update back to the regular stable firmware - firmware-2.2.img.zip (277.4 KB)
You also have to send that (very large) sysex file to the Electra using MIDI-Ox or Sysex Librarian.
After sending that file, the graphics will be corrected, then install the 2.2 firmware.
I did this process 2 days ago. If you follow all the steps exactly, it will recover the Electra One.
Yup, I wanted to mention, that it crucial part is to upload the sysex file when 3.x software is running. @duster if you have troubles with that, we can do that together on a video call or something like that.
For some reason, my “classic” electra.one (#0365) got stuck in such state after the 3.5.4 update, when managing the profile collection.
Restoring the SD content after having disassembled the unit did not work.
The SysEx had to be sent to the « Electra Controller » MIDI port, whilst the web based manager is detecting the unit on the « MIDIIN3 (Electra Controller) and « MIDIOUT3 (Electra Controller) » ports afterward.
Re-did the whole process, using MIDI-OX to send the SysEx, and voilà! Thanks again.
