Hi ! Ok i tried to “see” the log file through the electra one console but i didn’t manage to connect it while it’s on the webeditor …
Then i supposed it was not the good way to what you wanted me to do .
First i am on the firmware 2.2 , hardaware 2.4 . I don’t beta test the V3
1: I changed the cable . same problem remains.
2 : i tried to understand what …“What would help would be seeing the log file of loading the “drunk” option list preset. If the Option labels are broken in the log file. They get broken during the USB transfer. If there are correct in the log (during the preset load) not malformed on the screen, it means the data is broken in the memory.” …
means… And I tried hard to “see” the log of the loading “drunk” file …
I opened the Electra one console, then, i could not manage to connect it while i am on the webeditor. Then managed to connect to the E.O.C but then how to load a preset …the snaps preset ? then i saved one and loaded it on the E1 . i had that :
1081612 displayMenuWindow: menu window shown
1081612 displayHintWindow: hint window shown
1082242 displayMenuWindow: menu window shown
1084212 changeSnapshotLambda: saveMode=0, bankNumber=0, slot=0
1084213 file to load: ctrlv2/snaps/UwYjYXYQNeDM3nISWdtL/s0000.snp
1084214 ParameterMap::load: file: filename=ctrlv2/snaps/UwYjYXYQNeDM3nISWdtL/s0000.snp
1084215 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=28, midiValue=0
1084215 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=29, midiValue=0
1084215 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=30, midiValue=0
1084216 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=31, midiValue=0
1084216 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=32, midiValue=0
1084216 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=33, midiValue=0
1084216 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=34, midiValue=0
1084216 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=35, midiValue=0
1084216 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=52, midiValue=0
1084217 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=53, midiValue=0
1084219 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=54, midiValue=0
1084219 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=55, midiValue=0
1084219 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=56, midiValue=0
1084219 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=57, midiValue=0
1084219 ParameterMap::parseParameters: deviceId=6, messageType=1, parameterNumber=58, midiValue=0
1084219 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=20, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=21, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=22, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=27, midiValue=127
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=25, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=23, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=24, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=52, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=53, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=54, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=55, midiValue=0
1084220 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=56, midiValue=0
1084223 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=57, midiValue=0
1084223 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=58, midiValue=0
1084223 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=20, midiValue=0
1084223 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=21, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=22, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=23, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=24, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=25, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=26, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=27, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=120, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=52, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=53, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=54, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=55, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=56, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=57, midiValue=0
1084224 ParameterMap::parseParameters: deviceId=2, messageType=1, parameterNumber=58, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=4, messageType=1, parameterNumber=20, midiValue=6
1084227 ParameterMap::parseParameters: deviceId=4, messageType=1, parameterNumber=21, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=4, messageType=1, parameterNumber=22, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=4, messageType=1, parameterNumber=25, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=4, messageType=1, parameterNumber=23, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=4, messageType=1, parameterNumber=24, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=121, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=122, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=123, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=1, messageType=1, parameterNumber=124, midiValue=0
1084227 ParameterMap::parseParameters: deviceId=1, messageType=6, parameterNumber=0, midiValue=2
1084227 ParameterMap::parseParameters: deviceId=1, messageType=2, parameterNumber=7, midiValue=0
1084227 ElectraApp::sendAllControls: need to send all controls
1084227 ElectraApp::sendAllControls:device: 1
1084227 sendMessage: port=0, channel=1, type=cc7, parameterNumber=29, midiValue=0
1084227 sendMessage: port=0, channel=1, type=cc7, parameterNumber=20, midiValue=0
1084227 sendMessage: port=0, channel=1, type=cc7, parameterNumber=21, midiValue=0
1084227 sendMessage: port=0, channel=1, type=cc7, parameterNumber=22, midiValue=0
1084227 sendMessage: port=0, channel=1, type=cc7, parameterNumber=27, midiValue=127
1084227 sendMessage: port=0, channel=1, type=cc7, parameterNumber=25, midiValue=0
1084228 sendMessage: port=0, channel=1, type=cc7, parameterNumber=23, midiValue=0
1084228 sendMessage: port=0, channel=1, type=cc7, parameterNumber=24, midiValue=0
1084228 sendMessage: port=0, channel=1, type=cc7, parameterNumber=52, midiValue=0
1084228 sendMessage: port=0, channel=1, type=cc7, parameterNumber=53, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=54, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=55, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=56, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=57, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=58, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=121, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=122, midiValue=0
1084247 sendMessage: port=0, channel=1, type=cc7, parameterNumber=123, midiValue=0
1084248 sendMessage: port=0, channel=1, type=cc7, parameterNumber=124, midiValue=0
1084248 sendMessage: port=0, channel=1, type=programChange, programNumber=2
1084248 sendMessage: port=0, channel=1, type=cc14, parameterNumber=7, midiValue=0
1084248 ElectraApp::sendAllControls:device: 2
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=20, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=21, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=22, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=23, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=24, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=25, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=26, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=27, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=120, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=52, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=53, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=54, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=55, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=56, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=57, midiValue=0
1084248 sendMessage: port=0, channel=2, type=cc7, parameterNumber=58, midiValue=0
1084248 ElectraApp::sendAllControls:device: 4
1084248 sendMessage: port=0, channel=4, type=cc7, parameterNumber=20, midiValue=6
1084248 sendMessage: port=0, channel=4, type=cc7, parameterNumber=21, midiValue=0
1084248 sendMessage: port=0, channel=4, type=cc7, parameterNumber=22, midiValue=0
1084248 sendMessage: port=0, channel=4, type=cc7, parameterNumber=25, midiValue=0
1084248 sendMessage: port=0, channel=4, type=cc7, parameterNumber=23, midiValue=0
1084249 sendMessage: port=0, channel=4, type=cc7, parameterNumber=24, midiValue=0
1084249 ElectraApp::sendAllControls:device: 6
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=28, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=30, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=31, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=32, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=33, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=34, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=35, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=52, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=53, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=54, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=55, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=56, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=57, midiValue=0
1084249 sendMessage: port=0, channel=6, type=cc7, parameterNumber=58, midiValue=0
1084249 displayPage: page shown: page=11, controlSetId=-1
And i saw nothing wrong ?
How can i load the E1 Preset from the E1 or load it as a file ? is it possible ?
More than that i will not have nor the time or the patience to troubleshot all this . How can i send it back to you to check all this ? what’s the procedure ? Is the shipping is in the warranty ? i will continue to see that on another computer . Certainly on sunday . If there is nothing to do i will send it to you on monday i think . I have all the packages and will use UPS like you . lol. I was sooo happy to begin to play with it . But, things happen
. That’s life . Keep in touch for the procedure ? Thanks for your help !
have a nice day !!!! ;)
