Inactive Control Sets - bring back Dim?
Hi Martin, I haven’t found any discussion about that,
but I read that you intentionally killed the option to dim inactive Control Sets. I know you did it for a reason and so I’m trying hard to get used to it. But in busy live stage situations I can’t help myself but end up tweeking the knobs in the wrong Control Sets again and again and again…, because those thin bars on the sides are too discreet to recognize the active control set at first sight.
So if I didn’t miss anyhting here or in the Settings, I’m kindly begging to bring back the dim option. Is that possible? :slight_smile:
Yes, there was not any discussion as users generally accepted that change. The reason for that was making control set changes faster and simpler (in terms of the software implementation). I can bring the dim back. But I cannot return the highlighted background version. That one was the most resource consuming.
IMO dim would be perfect and a valuable option for everyone. If you bring it back: thank you so much!
I’ve recently moved over from a Mk1 to Mk2 and this is definitely a feature I miss! As it’s really clear which parameters are assigned when the other controls are dimmed.
same here! i definitely miss this one!
I think this is back in the new firmware (or at least the beta one I tried!)
It is back as per v4.1 and onwards. The feature can be enabled/disabled in the Settings :: User interface section.
