Sometimes when you look at a parameter, you may not remember how it works. Let’s take an example with Strymon TimeLine and the “Smear” parameter. It would be great if you could somehow bring up a window in Electra with a description of the parameter.
“Smear, softens the attack of the repeats while maintaining full frequency response. This allows for higher mix levels while keeping the delay out of the way of the dry signal. With high Repeats levels, the delayed signal gets dreamy and ethereal.”
mmm, in principle it works as a function “showHelp” added to a control, but currently the text being called is preventing the controllers from being tweaked and that is not the purpose. Can anyone think of a way the logic below could be fired in parallel with tweaking knobs?
And that could be stopped, once another control is being changed?
The code below is rough of course, and assumes three controls with ctrl# 1, 2 and 3, each with their own help text.
The text is scrolling on the lowest line at the right. It waits for 0,4 s then scrolls one character per 0,075 seconds.
helpTxt = {}
previousCltId = 0
function showHelp(valueObject, value)
local currentCltId = valueObject:getControl():getId() -- ref id
if currentCltId == previousCltId then return end
previousCltId = currentCltId
helpTxt[2] = "Smear, softens the attack of the repeats while maintaining full frequency response. This allows for higher mix levels while keeping the delay out of the way of the dry signal. With high Repeats levels, the delayed signal gets dreamy and ethereal."
helpTxt[1] = "Explanation for control 2"
helpTxt[3] = "Explanation 3 "
for i = 1, math.max(#helpTxt[currentCltId]-19,1) do
info.setText(string.sub(helpTxt[currentCltId],i,20+i))
if i == 1 then helpers.delay(400) end
helpers.delay(75)
