Hello, I want to add a MagSafe ring to the base of my Electra Mk2 so I can easily put it on a couple of stands I own. I assume the magnets in the ring & stand won’t break anything but wanted to check before I mess up a perfectly good unit!
I’d be very careful - E1 Mk2 is substantially larger and heavier than even the heaviest iPhone, and the magsafe magnets may not provide sufficient attraction. I am not saying it will just fall off, but when you operate the unit - twist knobs or tap the screen - chances are magnets become dislodged.
If you want to mount it on a stand - I’d consider some clamping solutions, like tripod mounts for larger tablets. Good ones would clamp the body quite securely, offering rubberized grippy pads on the clamps.
it will not affect the electronics inside the controller
