the option for a round regulator display would be good. key commands as with elgato streamdeck!?
I am not sure what you mean. Can you elaborate it a little bit more. Thanks!
It is definitely possible. I also tested that (Electra must pretend to be a USB keyboard). I am not sure how to go about that yet. If it should be part of the current firmware or make special separate firmware for it…
that sounds good ! Then it would be the perfect controller for me.
ok i mean the graphic representation. it would be good if you had a round graphic for the regulator.
