I don’t know how useful this might be to the general population, but I had a need and so here’s a LUA discovery that might help folks.
Goal - I want to change the name/destination/value of a set of controls (tracks 1-8). Sometimes I want the control to change volume, or pan position or other stuff. Ideally, I want to be able to save the last set value so when I come back to a control that’s been edited, the display reflects the current value.
To start, I set up some arrays with default values:
ccMap = {38, 39, 40, 41}
trkCCName = {"Volume", "Feedback", "Pan", "Speed"}
trkVol = {127, 127, 127, 127, 127, 127, 127, 127}
trkFbk = {127, 127, 127, 127, 127, 127, 127, 127}
trkPan = {64, 64, 64, 64, 64, 64, 64, 64}
trkSpd = {127, 127, 127, 127, 127, 127, 127, 127}
Then I set up an array to access these things (has to be defined after the initial arrays):
tblIdx = 1
trkTbl = {trkVol, trkFbk, trkPan, trkSpd}
I defined a virtual fader to select what function will be used. The fader has a min=1, max=4, and a list array of strings and values. Each track control will send out a MIDI Note and a MIDI CC, so there’s some processing to get the CC associated with the function here. Currently, the 8 track controls have IDs 31-38 (working on removing some hardcoding - functionality first though):
function setTrkCC(ValueObject, Value)
tblIdx = message:getValue ()
local valueTbl = trkTbl[tblIdx]
ccFn = ccMap[tblIdx]
for i=1,8 do
local ctl = controls.get(30 + i)
ctl:setName(string.format("%s %d", trkCCName[tblIdx], i))
parameterMap.set(1, PT_VIRTUAL, 30+i, valueTbl[i])
Next, each of the 8 track faders call this LUA function to actually send out the values:
function trkCCFunc(ValueObject, Value)
local control = ValueObject:getControl()
local ctrlId = control:getId()
local trkNum = ctrlId - 30
valueTbl[trkNum] = Value
midi.sendNoteOn(PORT_1, 1, trkNum, 127)
midi.sendControlChange(PORT_1, 1, ccFn, Value)
The main thing I wanted to avoid was a bunch of “if then else” constructs to handle which table and value to use. By creating an array of array names, LUA lets you index into that, grab a name and then use that to get/set values. To extend it and add more functions per track is simply a matter of extending the array
