This is a tool I created to help map the values of the Access Virus Rack, as they weren’t documented. It can be run in a browser (only tested in Chrome).
I set up a pad on the Electra One to more conveniently trigger a dump. I used Midi Monitor on my MacBook to record the MIDI messages out of the synth. To use:
- Copy and paste one dump in the first text area, tweak a parameter on the synth, trigger a second dump, and paste that into the second text area.
- Press ‘Compare’
- The differences between the dumps are highlighted and the byte number is shown at the bottom of the page.
- Repeat.
