in Lua create such function. In it , first try to send the same value to both NRPN’s via the midi NRPN send function. Now you control both NRPN with one control
depending on how the Peak behaves you might have to add a split command, making the sent valuues different when the virtual control is below, on or above 4.
I have a Summit, but didn’t start yet on it with the E1. If you want I’ll experiment with it myself and provide you the Lua code.
Unfortunately I’ve been very busy last few months producing and mixing an album for a vocalist. Whilst my Electra has seen lots of use I’ve not had time to do any programming.
This is the sort of thing that novation do quite frequently which pre lua required multiple controls. Hopefully I’ll find some time in the spring to jump back into programming the Electra.
Don’t let this hold up whatever you want to do on the summit. If I didn’t already have a peak, and actually had room for another 5 octave keyboard, I would definitely be buying one of those.
Well, one day I’ll make a Summit preset, but I want it to work with patch parsing. I should be making it in such a way the patch parsing also works for Peak, but I’ll need your help then in some testing.
@RobinC FYI I’ve started the patch parsing on Summit. There are other weird things: when they needed a 256 resolution control, Novation did not split it in a LSB (bits 7-0) and MSB byte (bit 8). Instead they split it in a byte that covers only bit 0, and the other byte that contains bits 8-1. Doable though.
