Just in case you want to play Jump and you still need to tweak a few settings; here’s the preset for the Arturia OB-Xa from the V Collection 8. Again I didn’t bother with the advanced settings. Enjoy!
Hi @SmartBits, if you used the same filename extension for all mapping files, I could allow that the in the settings of the forum. The .pdf would not be needed then.
Thanks @martin , but like @shankar said it’s an Arturia thing. For each of their plugins they use a different extension for the mapping file. So unless you allow all extensions everey newly mapped VST would have to be added. I don’t think that’s feasable. I don’t mind changing it before uploading, it’s only a few seconds work. And it keeps the forum safer to allow fewer extensions.
